Low oil sensor
Old Apr 13, 2006 | 01:52 PM
kick Z tail out's Avatar
Low oil sensor
Do I need anything for the threads? I'm headed out to the auto parts store right now...
Old Apr 13, 2006 | 02:01 PM
FastZinTennessee's Avatar
Re: Low oil sensor
No.
Old Apr 18, 2006 | 04:37 PM
Re: Low oil sensor
Sheesh... Just picked up my new sensor, and it's plastic. :blah:
Old Apr 18, 2006 | 06:05 PM
T/A Racer's Avatar
Re: Low oil sensor
hey i need one of these since i broke the last one pullin the pan off for a rebulid. anyways mind if asked how much yours cost.
thanks
Old Apr 18, 2006 | 06:23 PM
Re: Low oil sensor
thanks
It was $40 at Star Auto Parts. I guess the dealer charges a lot more.
Old Apr 18, 2006 | 06:31 PM
MENEGRANDE's Avatar
Re: Low oil sensor
is that the same as the sending unit??
Old Apr 18, 2006 | 06:36 PM
Re: Low oil sensor
It's a sending unit, but not for the oil pressure. It's in the side of the pan and all it does is trigger the idiot light on the dash if your oil level gets too low.
I'll be putting it on tomorrow.
Old Apr 18, 2006 | 06:38 PM
eds96ragtop's Avatar
Re: Low oil sensor
it is not the oil pressure sending unit but the level sensor two different things
the level sensor is in the oil pan near the bottom.
edit oops he beat me to the answer.
Old Apr 18, 2006 | 06:41 PM
MENEGRANDE's Avatar
Re: Low oil sensor
ahh ok, cause i had to change the sending unit on my camaro some time ago...and you are right, it's a cheap plastic looking thing... it cost me 37.00 at auto zone
Old Apr 19, 2006 | 09:51 AM
OBE1 95Z28's Avatar
Re: Low oil sensor
It installs with a seal (looks like a metal washer with rubber in the middle).
Old Apr 20, 2006 | 12:46 AM
infinitebird's Avatar
Re: Low oil sensor
I need to get one of these too? What's required to install it? Do you need to drop the oil pan?
Old Apr 20, 2006 | 01:00 AM
Re: Low oil sensor
Only when half of the oil sensor crumbles and breaks off inside the pan while you're trying to take it off... Like mine did today
Otherwise, if it doesn't fall apart, no. If you have the stock y-pipe, you may or may not need to remove it. It takes an 1 1/4" wrench.
Old Apr 20, 2006 | 11:17 PM
97Whitez28's Avatar
Re: Low oil sensor
I'm pretty sure that '96 and '97 cars don't have the seal.......
Old Apr 20, 2006 | 11:23 PM
Eff's Avatar
Eff
Re: Low oil sensor
my 94 didnt have a seal and never leaked, but I think I did put thread sealer on it when i replaced it, just in case....
Old Apr 20, 2006 | 11:49 PM
KillWhitey's Avatar
Re: Low oil sensor
My 94 does not have the seal. I have read alot about the leaks but mine has never leaked.
