CamaroZ28.Com Message Board
-   -   Low Oil Level Sensor (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/low-oil-level-sensor-225195/)
Gripenfelter Feb 15, 2004 04:37 PM
I know where the sensor is.
Where does the harness come from?
Which wire loom is it out of?
I can't find it.
InjectedSS Feb 15, 2004 04:42 PM
Re: Low Oil Level Sensor
I can't find it.
It goes strait up into the harness that is right by the oil pressure sensor as well. Like the wire loom that holds all the injector wires, ignition coil wires etc, its in that same loom.
If you need a pic lemme know!
Gripenfelter Feb 15, 2004 05:18 PM
Thanx.
Yes a pic would help
DesiZ28@hotmail.com :)
shoebox Feb 15, 2004 07:55 PM
Harness
Gripenfelter Feb 15, 2004 08:31 PM
Thanx Rob.
