low coolant light
It's a common problem. You can try to clean it, just replace it or you have the option of just unplugging it to kil the lamp on the dash. Unplugging it won't affect anything but the lamp. The sensor is not tied to the pcm.
Have you bled the lines? Are you running 5-10% coolant minimum? If both of these are a yes, then you may have a dead/dying sensor in the water pump, some people claim to clean them off with some success.
Mine also came on and I checked the level and it was OK. It finally went off about a week later and after that the damn thing overheated and spit all of the coolant out of the filler cap
Got it flushed and haven't had a problem since
gm parts direct
part number 10096163, think it's about $30 with shipping.
now i stopped and asked Discount Auto once and they said they had one for around $9....i was a bit skeptical. i didn't buy it since i didn't have the cash at the time. but it's worth lookin into.
Jan 23, 2015 01:13 PM
