CamaroZ28.Com Message Board
-   -   Low Coolant Light (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/low-coolant-light-428406/)
1FRANZ Feb 6, 2006 05:06 PM
Low Coolant Light
I reciently noticed my low coolant light was fading on and off.. I decided it had been forever since I had Flushed and changed my coolant, so I did that.. Now the Low Coolant light is still fading on and off. I have checked the levels several times and everything is fine. Ive also bled the system and there is no air that i can find.. Any ideas???
engineermike Feb 6, 2006 05:17 PM
Re: Low Coolant Light
The sensor in the radiator is bad. Everyone has that problem.
JP94Z Feb 6, 2006 05:19 PM
Yeah, after about 5 times of checking to make absolutely sure it wasn't really low, I finally just unplugged the sensor.
crAzy95z28 Feb 6, 2006 05:21 PM
when u unplugged the sensor, did it make the light go away?
LJ93Z28GM Feb 6, 2006 05:27 PM
yes light goes away and no problems are made by unplugging it.
6SpdLT1Z Feb 6, 2006 05:30 PM
Mines been going off. But it's been overheating also. My thermostat is stuck. :(
94arcticwhiteM6 Feb 6, 2006 05:39 PM
check the connector on the module on the tank
if its an 8-pin plug its gm number 12135027
if its a 2-pin plug its gm number 10096163
OBE1 95Z28 Feb 6, 2006 05:45 PM
It's a low cost sensor, just replace it and have the protection of the sensor function.
1FRANZ Feb 7, 2006 07:15 AM
Thanks for all the ideas.. This really sucks, The temperature sensor went out last week on my Jeep now the Coolant Level sensor goes out this week on my T/A... Thats some luck..
scottslt1z28 Feb 7, 2006 07:46 AM
just an FYI, the sensors are pieces of crap (like someone said earlier) mine did that a long time ago and after checking it a couple times i just unplugged it. From then on out i just made sure i checked it everytime i washed the car (same time i check all fluid levels).......so i wasnt worried about it, but i did just now replace it. (after a year and half or 2 years without it i believe....haha)
I think i got mine for $30 shipped from jason chromer. for how cheap they are i would just go ahead and replace it, but i am anal about things on the car. So ya know
But b4 you do unplug it MAKE sure you dont have a tear or a spot in one of the coolant hoses that has dry rotted. That would be a huge problem.
Gl man
Z28LT1_Just_Nasty Feb 7, 2006 09:56 AM
Was happening to me, then I overheated and blew a headgasket and warped a head. Always be very wary about your coolant.
revtime Feb 8, 2006 12:32 AM
Hmm you guys are spoiled by modern technology. :lol:
My sensor went bad and turned the lite on so I pulled the bulb out of the cluster.
My feeling is if my old musclecars didn,t have it then my new musclecar don,t need it either.
No airbags, no 4 speed electronically controlled transmission, no coolant level sensor.
I cheat sometimes though.......I am keeping the fuel injection. :D
Cmr0z28 Feb 8, 2006 12:43 AM
Mine's unplugged. :)
