Low Coolant Light
Old Feb 6, 2006 | 05:06 PM
1FRANZ's Avatar
Low Coolant Light
I reciently noticed my low coolant light was fading on and off.. I decided it had been forever since I had Flushed and changed my coolant, so I did that.. Now the Low Coolant light is still fading on and off. I have checked the levels several times and everything is fine. Ive also bled the system and there is no air that i can find.. Any ideas???
Old Feb 6, 2006 | 05:17 PM
engineermike's Avatar
Re: Low Coolant Light
The sensor in the radiator is bad. Everyone has that problem.
Old Feb 6, 2006 | 05:19 PM
JP94Z's Avatar
Yeah, after about 5 times of checking to make absolutely sure it wasn't really low, I finally just unplugged the sensor.
Old Feb 6, 2006 | 05:21 PM
crAzy95z28's Avatar
when u unplugged the sensor, did it make the light go away?
Old Feb 6, 2006 | 05:27 PM
LJ93Z28GM's Avatar
yes light goes away and no problems are made by unplugging it.
Old Feb 6, 2006 | 05:30 PM
6SpdLT1Z's Avatar
Mines been going off. But it's been overheating also. My thermostat is stuck.
Old Feb 6, 2006 | 05:39 PM
94arcticwhiteM6's Avatar
check the connector on the module on the tank
if its an 8-pin plug its gm number 12135027
if its a 2-pin plug its gm number 10096163
Old Feb 6, 2006 | 05:45 PM
OBE1 95Z28's Avatar
It's a low cost sensor, just replace it and have the protection of the sensor function.
Old Feb 7, 2006 | 07:15 AM
1FRANZ's Avatar
Thanks for all the ideas.. This really sucks, The temperature sensor went out last week on my Jeep now the Coolant Level sensor goes out this week on my T/A... Thats some luck..
Old Feb 7, 2006 | 07:46 AM
scottslt1z28's Avatar
just an FYI, the sensors are pieces of crap (like someone said earlier) mine did that a long time ago and after checking it a couple times i just unplugged it. From then on out i just made sure i checked it everytime i washed the car (same time i check all fluid levels).......so i wasnt worried about it, but i did just now replace it. (after a year and half or 2 years without it i believe....haha)
I think i got mine for $30 shipped from jason chromer. for how cheap they are i would just go ahead and replace it, but i am **** about things on the car. So ya know
But b4 you do unplug it MAKE sure you dont have a tear or a spot in one of the coolant hoses that has dry rotted. That would be a huge problem.
Gl man
Old Feb 7, 2006 | 09:56 AM
Z28LT1_Just_Nasty's Avatar
Was happening to me, then I overheated and blew a headgasket and warped a head. Always be very wary about your coolant.
Old Feb 8, 2006 | 12:32 AM
revtime's Avatar
Hmm you guys are spoiled by modern technology.
My sensor went bad and turned the lite on so I pulled the bulb out of the cluster.
My feeling is if my old musclecars didn,t have it then my new musclecar don,t need it either.
No airbags, no 4 speed electronically controlled transmission, no coolant level sensor.
I cheat sometimes though.......I am keeping the fuel injection.
Old Feb 8, 2006 | 12:43 AM
Cmr0z28's Avatar
Mine's unplugged.
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
