LOW Coolant Light
I pulled my motor a couple months ago and just put it back in, when iI installed it, my low coolant light will not turn off, any ideas.
Oh I changed my steering wheel too, does anyone know how to turn of the airbacg sensor in the dash cause I went with a Grant wheel. |
Airbag - remove the fuse for the light, or remove the light.
As for the coolant, the sensor's worthless. Mine's been flicking on and off over long periods for 6 months. Coolant is fine. |
i knew the coolant was fine cause i just filled it but any ideas on how to get rid of that light
Originally posted by Spinner As for the coolant, the sensor's worthless. Mine's been flicking on and off over long periods for 6 months. Coolant is fine. |
replace the sensor, i wouldnt beat around the bush on this one, although its a dummy light it could save your butt some day!!
If you just want to get rid of the light, all you have to do is unplug the sensor and the light will go off.
