Lost bolt (cat to i-pipe clamp)
Old Oct 13, 2003 | 12:38 PM
mike95z28
Guest
Posts: n/a
The exhaust note had an odd twist on my car. Upon inspection of the exhaust.. it turns out the bolts that clamp the ball-looking-joint area to the cat loosened up quite a bit. One of the bolts managed to fall out on to the road somewhere.
Anyway... is there a specific part number or size for this bolt? It looks like it screws and tightens to the clamp piece. If there isn't a specific part #.. any specific nut/bolt I could replace it with?
Thanks.
Old Oct 13, 2003 | 12:53 PM
ead94z28's Avatar
If you are talking about the joint at the rear of the cat the pn for that bolt is: 1636152
Old Oct 13, 2003 | 02:01 PM
mike95z28
Guest
Posts: n/a
That sounds like it might be it. Where did you find the part number? Just curious so I can see a pic to verify.
Old Oct 13, 2003 | 02:13 PM
ead94z28's Avatar
http://csce.uark.edu/~jgbertr/rb/exhaust_system.jpg
I cross refrenced the part labled 9 with my parts manual.
Old Oct 13, 2003 | 02:24 PM
mike95z28
Guest
Posts: n/a
Yup. That looks like it's it. Thanks for the info/pic. I appreciate it.
The only confusing thing is... the bolt looks like it should screw in in the opposite direction.
Old Oct 13, 2003 | 02:33 PM
ead94z28's Avatar
Smile
I can tell you that mine bolts back to front, with the nut facing the front of the car, like the pic.
Old Oct 13, 2003 | 02:39 PM
89irocz23's Avatar
I think he has dual cats so its a different bolt..its pretty a band clamp bolt. Shoebox proly knows a part number for that.
Old Oct 13, 2003 | 03:04 PM
ead94z28's Avatar
mike95z28, dual or single cat?
Old Oct 13, 2003 | 11:39 PM
mike95z28
Guest
Posts: n/a
Single cat.
I tightened up the remaining bolt.. I don't remember but I tought it threaded front to back. Could be wrong.
maybe2fast
Mar 16, 2015 09:45 AM
transam_388
Mar 15, 2015 11:53 AM
crazypurgatory
Jan 12, 2015 10:45 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
