losing power at higher throttle engine just revs
when i hit the gas i got lots of power but if i hit the throttle a little hard or trying and floor it the car goes nowhere and the engine revs. theres come kind of power distribution problem. anyone have any ideas? my first thought is that the torque converter is slipping.
94 lt1 a4 |
Any chance the tires have lost traction and are just spinning. Not uncommon for first or second gear :)
My guess would be the tranny is going out,
Give CPT one of the sponsers here a call and he should be able to hook you up with what you need. |
tires arent spinning, seems like the tranny slips outts gear. i have a small tranny line leak that i need to replace the line to fix, would this slight loss of pressure cause the give out?
aaaaaaaaaaa....your bands are gone in your 4L60E, and its time for a rebuild if the traction thing is not your problem... dont beat on it because pretty soon you will go no where and youll have the prettiest paper-weight in your neighborhood :D
well that sucks. any way to know how long i have? im not gunna have money for about 6 months and i wont rebuilt ill go with a 6 speed but i need it to last as long as possible.
