CamaroZ28.Com Message Board
-   -   locking header bolts (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/locking-header-bolts-155348/)
lt4 fd Aug 7, 2003 12:23 AM
the locks wont fit on some of the bolts since the bolt is sooo close to the header primary, do you have to shave them down or what?
1982z28with18s Aug 7, 2003 12:58 AM
Yep, just snip them to fit. To make it easier so you don't drop them you can tie fishing line or string around the clip and the other end to your finger so when you drop them you can get them back.
BUBBA Aug 7, 2003 09:50 AM
ARP 1" SS 12PTS.:cool:
Bud M Aug 7, 2003 06:48 PM
I had to grind on a couple of mine to get them to fit. I used my bench grinder.
joefreeland Aug 7, 2003 10:42 PM
try turning the bolt a 1/8 of a turn. I did that to some on mine and the locks fit right on. also you cant flip the Locks. The hex is offset to the notch on the locks. Sometime if you flip the locks they will fit. I had slp single cat 1 3/4 headers.
Z95m6 Aug 7, 2003 10:58 PM
i had to grind only a few of mine but that is because one of my header tubes has had a modification and a weld was in the way. Mine are SLP single cats too
EviLZ28 Aug 7, 2003 11:15 PM
Anyone have the new locks out there yet. I am gonna order a set from http://www.go-breslin.com/ They use an allen stud to lock the bolt into the head. Pretty cool set-up.
