location of knock module on a lt1
i have a 1995 pontiac formula. i purchased a lt4 knock module. and a friend of mine is going to install it..but he cannot find the location of the module. can someone give me a detailed description as to where it is? thanks
Steve |
Re: location of knock module on a lt1
If he cant find it DO NOT let him install it. It is located directly in the engine PCM/ECU. It's held in by two screws. You should be able to install it yourself.
what he said. I also hope that you bought the knock for the PCM and not for the block.
Lmao... or were you taking about a different location :)?
that seems about right heh hopefully i got the right sensor...i think i did thanks for the help
Steve |
