Little lights above window switches/door locks...
I noticed that the little red light above my driver's side widow switch/door lock buttons is burned out. Where can I get a new one and how do I go about replacing it?
Thanks! J |
It is simple. You can get a new bulb from most autoparts stores. I got mine from Advance auto. just pop off the panal and there it is. you do have to pull the bulb out of place to re install the new one. good luck let me know if you need further advice
