Lifter Retainer Hardware
Old Mar 10, 2006 | 11:52 PM
3gc's Avatar
3gc
I misplaced the bolts and washers that hold down the lifter retainer spider thing. I went to the dealer and bought the bolts for $2 a peice but couldn't see spending $5 a peice on the washers. I don't really feel too comfortable throwing hardware store washers inside my engine. I was hoping to find hardened washers somewhere but haven't come across them yet. Anyone have any ideas or should i just spend the $20 and order the washers monday?
Old Mar 11, 2006 | 12:42 AM
SStrokerAce's Avatar
Re: Lifter Retainer Hardware
ARP has them, call them up.
Bret
Old Mar 11, 2006 | 01:00 AM
Compstall's Avatar
Your's had washers? Mine didn't.
Old Mar 11, 2006 | 01:15 AM
Javier97Z28's Avatar
Moderator
I've never seen one with washers.
Old Mar 11, 2006 | 01:32 AM
3gc's Avatar
3gc
I remember mine had washers and in the parts manual it shows washers with a part number. I found the part number to what i need on the ARP website, 200-8585. Summit only carries the 10 pack of them, so and after paying for shipping I'm only going to save like 2.50. I guess i'll just order it from the dealer on monday, usually parts arrive the next day at the dealer.
Old Mar 11, 2006 | 01:34 AM
3gc's Avatar
3gc
Maybe I should just throw it in without washers.
Old Mar 11, 2006 | 02:09 AM
Moderator
My 97 nor my friend's 96 had washers... both cars previously untouched. I think you'll be fine..
Old Mar 11, 2006 | 05:27 AM
Loadre's Avatar
I don't have washers.
Old Mar 11, 2006 | 08:25 AM
Stoopalini's Avatar
Mine didn't have washers either, but the GM lifter package I purchased when replacing the lifters and retaining hardware came with bolts and washers; so I installed them.
Thomas.
Old Mar 11, 2006 | 08:48 AM
Compstall's Avatar
Thomas.
Mine didn't
Old Mar 11, 2006 | 08:56 AM
Colin91Z's Avatar
I've never seen washers on there on an LT1 I've ever worked on
Old Mar 11, 2006 | 09:35 AM
Kevin Blown 95 TA's Avatar
If you got your heart set on using washers, just get some that are the right size and use a drop of blue Locktite on the threads of the bolts and it will be fine. Cheap hardened washers might crack, but mild steel would be OK. Don't make it more difficult than it is. It's not under any stress - you just don't want it to come loose.
Old Mar 11, 2006 | 12:06 PM
3gc's Avatar
3gc
I talked to Chad over at Golen and he confirmed that from the factory they don't use washers. I just get real paranoid about things sometimes. I have so much invested in this motor I don't want something as silly as a washer causing a problem. I'll throw them in with no washers and put some locktite on it.
Thanks everyone.
G-BODYT56
Jan 14, 2022 11:14 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
alliance12364
Sep 23, 2015 06:09 AM
Z Power
Sep 19, 2015 11:19 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
