CamaroZ28.Com Message Board
-   -   Let's play name this part (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/lets-play-name-part-465664/)
1LESSZ28 Aug 9, 2006 04:38 PM
It is a vacuum hose that goes into the manifold on the passenger side. Mine is cracked.
It has "1/4 GM6148-M 111596" imprited in white on it. That didn't seem to be the part# though. It is just some thick vacuum hose about 5" long. I will try to post a pic later when I can get access to a camera.
It goes into a square boxy piece with an electrical connector with a red and teal clip. The other connector is adjacent to the oil cap and also has a teal connector. Should I just go pick up some vacuum hose or is there a part #?
I know someone who gets a discount
EuroticCustoms Aug 9, 2006 10:38 PM
Re: Let's play name this part
go to a junk yard. They'll probably just give you one.
ulakovic22 Aug 9, 2006 11:47 PM
It sounds like the vacuum hose for the EVAP system?
http://shbox.com/1/evap_sol.jpg
1LESSZ28 Aug 10, 2006 12:00 AM
Yeah that's it! I'll have to check shoe's site for a p/n. Thanks for the link
