CamaroZ28.Com Message Board
-   -   Leak between the... (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/leak-between-126468/)
Rodrigues May 29, 2003 02:40 PM
Leak between the...
I have a leak between the master cylinder and the brake booster. What could be causing this? I don't recall there even being a gasket there! I'll replace it if I have to, should I use some kind of rtv?
shoebox May 29, 2003 02:46 PM
The only thing that could be leaking is the master cylinder. It must be dripping out the rear of the master cylinder. You can get a rebuild kit or replace it.
