leak??
Old Feb 3, 2003 | 10:02 PM
flyingaaron2's Avatar
Angry leak??
hey today i woke up and there was a big puddle under my car..it looked white..the groud was really wet to so it kinda mixed with it..car drove bad today when i took it to work..it had a weird idle..when i had it in drive and my foot on the brake the rpms would move about 3 hundred. any ideas?
Old Feb 3, 2003 | 10:29 PM
MauriSSio's Avatar
did you check your oil? you could potentially have a VERY big problem on your hands
Old Feb 3, 2003 | 10:31 PM
hey no i havent checked anything yet...but im thinking it could be oil mixed with something..cause the water basically wipes right off the fluid..whta do you think it wuolc be?
Old Feb 3, 2003 | 10:48 PM
Wild1's Avatar
There is no fluid in your car that is white unless you are running Ajax in you cooling system. What does it smell like? Oil and water will turn "milky" or "chocolate milk" which is very bad. You could have an oil leak and with all of the water around perhaps it is splashing up and "washing" the oil off of the engine. Before I turn that key, I'd check EVERY fluid (Oil, Trans, Coolant, Power Steering, even the Brake level). Something is up. Was the leak there when you pulled into the parking spot?
MauriSSio's Avatar
ok,you might have a blown head gasket and the stuff thats leaking might actually be oil mixed w/coolant (a common problem when you have a blown head gasket).When oil mixes w/water/coolant it gets thicker and whiteish,this blend accelerates damage to the bearings and other moving parts in the engine,so if its a head gasket,dont drive it too much if at all. Has your car overheated any time recently?lots of times all it takes is a good overheat to blow a head gasket.First and most importantly thing to do is check the oil,post again after that is done so someone on this board (sorry i got to peace out right now ill check this post later)can further diagnose your cars problems.Do keep this in mind-Lots of times i get the feeling my car isnt running "right" but thats just my mind playin tricks on me,just LOOKING for something thats not there,you know what im sayin?well,good luck!
Old Feb 3, 2003 | 11:03 PM
alrlight i went out..i checked all the fluids they all look fine..at work nothing leaked from under the car..and nothing has since ive been home.
Old Feb 3, 2003 | 11:10 PM
oh and i have not had any problems with the car overheating..and it does kinda look like darker milk.
Old Feb 4, 2003 | 12:06 AM
Wild1's Avatar
Keep you eyes open. If the fluids are good then start the car. If it idles good, then just watch the car closely for a few days. If it idles bad, then turn off the engine and run a compression test. It's time to check the head gaskets.
Old Feb 4, 2003 | 12:32 AM
alright ill keep an eye on it..ill tell ya how it goes..thanks for the help
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
