CamaroZ28.Com Message Board
-   -   LCA question (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/lca-question-220634/)
RedHottG2 Feb 3, 2004 08:24 PM
LCA question
I have had a problem for awile now with a loud noise comming from the rear of my car and I put it on a lift today and discovered my driver side lower control arm was really loose. When I hit it on the sides, it would move from side to side :eek: . The other side seemed to still be alright. My question is when I got to replace my LCA's (BMR), should I replace my uppers also or if they are ok, will it be fine? Thanks for your help guys :cool: .
Spinner Feb 3, 2004 08:33 PM
There are no upper LCAs that I know of?
Or maybe im mistaken.
Are you talking about the A-Arms in the front?
93Z286Speed Feb 3, 2004 08:35 PM
there are no upper control arms in the rear, we dont have a 4 link set up.. basically we have a "2 link" set up :)
Z95m6 Feb 3, 2004 08:35 PM
there are no upper control arms on the back.
RedHottG2 Feb 3, 2004 08:38 PM
hmm...well I might be wrong about the upper control arms. I don't know that much about suspension. All I do know is that my driver side LCA is trashed on the driver side rear. Anyone else know anything about this ?
Spinner Feb 3, 2004 08:39 PM
Old bushing probably tore, or wore away. A new set should remedy the problem.
RedHottG2 Feb 3, 2004 08:39 PM
Thanks guys...I posted with out getting to read all the posts before hand. That clears it up for me. Thanks for the info!!
