Kooks y-pipe install problems... pics and a video inside...
Old Aug 10, 2006 | 01:58 AM
trax's Avatar
Exclamation Kooks y-pipe install problems... pics and a video inside...
I'm in the middle of my Kooks LT install. The headers themselves fit great, but something is seriously wrong with the Y-pipe.
I'm using stock motor mounts, a Kooks 6402S y-pipe, and Kooks 6400-1S headers. For test-fitting purposes the passenger-side header is firmly bolted in place at the header flange.
For those of you on broadband, I have a high-res, 55 second, 19mb video explaining the issue... click here. (Warning, I have the dumbest-sounding voice ever.)
Here's the basic problem: The rear part of the y-pipe that mates up to the catback points upwards, hitting the driveshaft, even with the rear suspension loaded (jackstands on the axle so the weight of the car is on the rearend). The end of the y-pipe is also in a goofy spot, below the driveshaft instead of next to it. Something has to be wrong with either the install or a mismatch in parts.
Pics:
Anyone know what's going on? Thanks!
Old Aug 10, 2006 | 10:17 AM
My Iroc Z28's Avatar
Re: Kooks y-pipe install problems... pics and a video inside...
pics didn't show up but is it possible that the y-pipe is upside down?
Old Aug 10, 2006 | 11:33 AM
1racerdude's Avatar
See if ya can shorten the passengers side will it swing the out pipe around to line up.
Old Aug 10, 2006 | 02:18 PM
trax's Avatar
Shortening the passenger side of the y-pipe is only going to move the entire assembly forward... the rear part will still be aimed upwards toward the driveshaft with almost no clearance.
Old Aug 10, 2006 | 02:29 PM
1racerdude's Avatar
Send it back then,and get one that fits.
Old Aug 10, 2006 | 03:20 PM
The Engineer's Avatar
My Kooks long tubes and the off-road y-pipe (no cats) all fit perfectly on my 97 Z28. So, I'm not sure why there is a problem? Check with George R at Kooks 866-586-5665 and he should help you out.
Is the slip-fit collector (passenger side) slid completely on until it stops? That could be causing the rear connection end of the y-pipe to be canted towards the drive shaft. That rear pipe shoud be running "exactly parallel" to the drive shaft and not pointed in like your pictures indicates. The picture of the y-pipe sections connected (just laying there) looks correct. Again, ensure the slip-fit on the passenger's is is completely slid on the flange.
http://www.cardomain.com/ride/2189634
Old Aug 10, 2006 | 03:28 PM
roguedriver's Avatar
I have the same setup. It looks like they welded that y-pipe up wrong. That short section that comes off the passenger side to connect into the drivers side of the y needs to be almost horizontal, not pointed down.
Ken R.
Old Aug 10, 2006 | 03:51 PM
BassProCamaro97's Avatar
Cool Re: Kooks y-pipe install problems... pics and a video inside...
Scrap that Y-pipe and get some true duals!!!!!
No seriously call them up and tell them that somethings wrong. Maybe if you can give them some measurments they can see if something was fabbed wrong. Im sure a company like that is great to deal with.
~Jim~
Old Aug 10, 2006 | 04:14 PM
ABA383's Avatar
Mine fit fine, too...I've been under my car trying to see what you could do to get it to fit...Is the driver's side slip fit pushed in all the way? How are your motor mounts? I would also call Kooks and see what they say...
--Alan
NewsBot
Jan 29, 2015 07:10 PM
97SSdude
Dec 31, 2014 07:43 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
