knocking noise, but good oil pressure?????
Old Apr 5, 2006 | 04:50 PM
95z28txn's Avatar
I put a rebuilt short block in my 95 z28. It starts and runs with 40 and up psi, but makes bad knocking type noise at under 2000 rpm. Rev above 3000 and smooth and it clears up for the most part. I already checked my stall and made sure wires are in the right order. Could it be the icm or somthing like that. It came up with no codes when i scanned it.
Old Apr 5, 2006 | 05:03 PM
Jazsun's Avatar
Re: knocking noise, but good oil pressure?????
If it was detonation you would prolly hear it at all rpms, tho im not positive. Sounds like a rod knock or some sort of spun bearing. I had a rod knock once and it would only do it at a certain rpm like 2-3k
Old Apr 5, 2006 | 05:50 PM
95z28txn's Avatar
I have zero miles on the rebuild though. The rebuild was from a very good local builder. Could it be any thing else?
Old Apr 5, 2006 | 10:59 PM
Matts1994Z28's Avatar
piston slap?
Old Apr 6, 2006 | 12:33 AM
blue94's Avatar
exhaust leak?
Old Apr 6, 2006 | 12:35 AM
Daniel6718's Avatar
sounds like a lifter rocker to me...as you bring up the rpm and oil pressure the lifter pumps up and knocking stops
Old Apr 6, 2006 | 10:39 AM
95z28txn's Avatar
those are all good suggestions that i will have to look into. If my valves are going to low and creating the noise can i put the stock rocker arms on to see if it makes it stop.
Old Apr 6, 2006 | 10:40 AM
95z28txn's Avatar
I am also not sure about my icm because it was a cheapy from autozone and i have heard autozone electronics are crap. It cost about a third of what other places are chargeing.
Old Apr 7, 2006 | 12:40 PM
95z28txn's Avatar
i am really scared that it is a rod knocking. My rebuilder did the job almost a year ago and i just finished it up recently. He is going to think i was driving it the whole time, and won't care that it is broken.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
