CamaroZ28.Com Message Board
-   -   Knock sensor (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/knock-sensor-606689/)
Shaun Quill May 19, 2008 03:51 PM
Knock sensor
Does anybody have a part number for an lt-4 knock sensor? My chevrolet dealer said it list the same number for lt-1 and lt-4 and I don't want to get the wrong one.Thanks,Shaun.
rcantrellz28 May 19, 2008 04:17 PM
GM# 16214681 ...........:) I beleive thats what you are looking for.
ShownomercyZ28 May 19, 2008 04:17 PM
The sensor or the module in the PCM?
rcantrellz28 May 19, 2008 04:18 PM
My above response is the part# the for the module , located in the pcm........by the way.
Shaun Quill May 19, 2008 04:36 PM
Thats a good Question,I believe you have to replace the knock sensor down on the side of the block don't you? Since the LT-4 is less sensitive it pulls less timing out Right? That's what I'm trying to do.I appreciate the help,Thanks
ShownomercyZ28 May 19, 2008 04:36 PM
I think the sensor on the block is the same on both the LT1/LT4, but the module is different.
rcantrellz28 May 19, 2008 04:39 PM
This is what I have been told as well.
rcantrellz28 May 19, 2008 04:42 PM
Just did a quick search and ran across this. This should help you....https://www.camaroz28.com/forums/sho...4+knock+module
shoebox May 19, 2008 05:21 PM
There is not a specific LT4 knock sensor.
wrd1972 May 19, 2008 05:22 PM
What he said.
Shaun Quill May 19, 2008 06:22 PM
That straightens me out. Thank you fellas very kindly,Shaun
Stl94LT1 May 19, 2008 06:45 PM
Isn't there different OBDI and OBDII knock sensors?
shoebox May 19, 2008 09:12 PM
Yes, but that was not the question here.
