knock retard
Using my laptop I noticed I had between 8-9 degrees of timing pulled at idle due to knock. Then after using datamaster I realized it had 5 to 9 degrees of timing pulled at wot. I've got the lt4 km and pcmforless tuning. Bryan suggested swapping back in the lt1 km(thinking the lt4 could be bad) so I did and at idle my knock went to zero and sometimes it jumps up to 3-4. At WOT it's anywhere from 0 to 5. Now, I swapped the lt4 back in and it immediately went back to 8-9 at idle and 5-9 at wot. Do you think the lt4 km could be bad, and the lt1 km could just be picking up that much knock? Or is their something else here that I'm just missing?
Thanks Justin |
i saw more retard w/LT4 than LT1 module in some test i've been doing the last few days. but also some runs with much less. after looking at my data, i believe the inconsistant retard is largely affected by even fairly small differences in coolant temp. what is you data showing as far as this?
I'd say get a new LT4, the reason poeple go to LT4s are because the LT1 KM's are more sensative. So I'd say that's why the LT1 KM is still picking up a little knock.
Originally posted by ibanez6rg the reason poeple go to LT4s are because the LT1 KM's are more sensative. |
I'm just saying get/borrow another LT4 KM to see if he gets the same results with the new one.
Re: knock retard
Originally posted by 1982z28with18s (thinking the lt4 could be bad) |
:confused:
OR
You could just have brian have desensitize your lt1 knock
i'm surprize that he wouldn't have done that in his performance tune. tony :confused: |
Here's what I came up with today. First off I talked to Bryan from pcmforless and he said that knock burst is programmed out. I went up to my buddies shop and used his snap on scanner for some testing.
First we had my lt4 km in, and at idle it showed between 5-9 degees of spark retard. Cruising it was almost always showing several degrees of spark retard. WOT it had 5-9 degrees of spark retard through the entire rpm range. Mostly stayed between 7-9 though. Next, we put in another lt4 km and had basically the same results as above except we had a few peaks of 10 degrees of spark retard. Also the entire time the "knock on/off", the knock was showing off at wot, and only came on a few times the rest of the time. Next, the lt1 km, at idle it was showing up to 4 degrees of spark retard, but for the most part it was none. Cruising it had none to 2 degrees of spark retard. At WOT, it had .1 spark retard until I hit 5300 rpms then the "knock on/off" changed to "on" and it pulled 7-9 degrees of timing. We did another run and at 5300 again it showed knock "on" and pulled 7-9 degrees of timing. Below that no timing was pulled though. Bryan from pcmforless thinks it the knock sensor, but I'm still not sure. I do have the obdI conversion from him. (thus I still have the obdII knock sensor) Any ideas guys? |
you could take out your LT1 module and wrap it in teflon tape, it is like adding ear muffs to it, essentially what the LT4 would do but cheaper!
Originally posted by My95Z you could take out your LT1 module and wrap it in teflon tape, it is like adding ear muffs to it, essentially what the LT4 would do but cheaper! Didn't you say teh exact same thing in another post. :rolleyes: |
mine has pretty much leveled out and i'm getting very little retard running 93 octane. have you tried running some high {100's} octane fuel to see if the knock your getting is actual combustion detonation or rather false knock caused by a loose bolt/bracket ect. or possibly picking it up from you dumping the exhaust in front of the rear axle?
Originally posted by 1982z28with18s Didn't you say teh exact same thing in another post. :rolleyes: |
Originally posted by mike 96 ws6 mine has pretty much leveled out and i'm getting very little retard running 93 octane. have you tried running some high {100's} octane fuel to see if the knock your getting is actual combustion detonation or rather false knock caused by a loose bolt/bracket ect. or possibly picking it up from you dumping the exhaust in front of the rear axle? Originally posted by My95Z umm... yeah. what I post in another post has nothng to do what I say here. He might not have read the other post so now would he know? I am here to help people and not just read posts to see if something has been said or not. [edit] Everyone else, thanks for the help. Once I get it figure out I'll make a post of what solved it. |
Originally posted by 1982z28with18s Everyone else, thanks for the help. Once I get it figure out I'll make a post of what solved it. |
