CamaroZ28.Com Message Board
-   -   knock mod help (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/knock-mod-help-467614/)
00JoeZ28 Aug 20, 2006 07:55 PM
knock mod help
What's the difference between an LT1 and LT4 knock mod.
Injuneer Aug 20, 2006 08:01 PM
Re: knock mod help
The knock module is a noise filter. The LT4 knock module was specifically tuned to block the noise signature from the Crane Gold roller rockers used in the LT4 engine, to prevent knock retard due to "false" knock.
00JoeZ28 Aug 20, 2006 10:11 PM
Re: knock mod help
What would happen then if I were to put an LT4 knock module on an 355 Lt1 with ported heads with 1.6 roller rockers? Non crane golds.
bringBackCamaro Aug 20, 2006 11:20 PM
Re: knock mod help
well, your car will most likely Burst into Flames upon switching to the LT4 knock module...
just kidding,
Most people on this board are running the LT4 knock module with various LT1 setups, it will help the computer filter out noise from a loud exhaust/cutout, headers, roller rockers, etc, etc
00JoeZ28 Aug 20, 2006 11:35 PM
Re: knock mod help
:lol:HA HA HA:lol:
Thanks for the info.
JustNO Aug 21, 2006 04:24 AM
Re: knock mod help
My LT headers touch my oil pan. Could LT4 KM filter that? Or thats could be the reason that my knock retard?
shoebox Aug 21, 2006 08:40 AM
Re: knock mod help
No KM is going to filter that.
Injuneer Aug 21, 2006 09:15 AM
Re: knock mod help
Its a simple filter. Its effectiveness on noises it was not designed to filter is debatable. It is not a cure-all for knock problems, false knock problems, banging exhaust systems, etc.
bowtiepwr Aug 21, 2006 09:22 AM
Re: knock mod help
>well you could always "Desensitze" you PCM. not recommended, but doable.
JustNO Aug 21, 2006 09:54 AM
Re: knock mod help
Yes thats an option, but I prefer to solve my problem. Obviously there is a problem and I can't feel comfortable by desensitze it.
Sparkz28ss Aug 21, 2006 10:57 AM
Re: knock mod help
Time would stand still..
get the car up and running...then worry about the tune....
.....and the Patriot Red Z, cause you are going to need 8lbs per min of n2o to even see the side of her door
