keyed hub install
keyed hub install
I'm supposed to get my keyed hub today, but a friend of mine said I was dumb to order one because there is no "key" on the LT1 crankshaft end. I thought the keyed hub went over that little tiny nub at the end of the crankshaft. Am I wrong and should I go out and buy a "key"?
BTW, good luck finding a threaded rod that is 7/16"-fine thread to install a hub. no one has it. I'm still searching.
Originally posted by shoebox
Yes, I would think that if you are installing a keyed hub, you would replace the cut-back LT1 key with a full (normal) key
stockssn2o
May 25, 2015 08:54 AM
cyteone
Feb 7, 2015 06:04 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
