CamaroZ28.Com Message Board
-   -   Keep same pushrod length? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/keep-same-pushrod-length-686959/)
meissen May 12, 2009 02:49 PM
Hey guys,
If I go with this lifter kit can I use the same pushrod length that I was using before?
http://store.summitracing.com/partde...2&autoview=sku
The stock pushrod length that I was using was good and I had bought Comp Cams hardened push rods so I'd just really like to get the car on the road without having to worry about having to buy new push rods again..
Hal Fisher May 12, 2009 04:39 PM
My best guess is yes. It only lists Gen I but even the LS7 lifters only list Gen III IV and we know they fit the Gen II. There is no lifter on Summits page that lists Gen II specifically. Maybe call if you are still not sure.
Hal
meissen May 12, 2009 08:21 PM
Thanks!
Stl94LT1 May 12, 2009 08:51 PM
Those are the stock replacement lifters. You can get the LS7 lifters quite a bit cheaper.
