K&n Cai
I have a newb question for you guys. Does anyone have a pic. of their k&n cai installed on their LT1 camaro? I was wonder how you get the filter down in the hole that is at the bottom of the engine bay b/c if you come from the bottom of the car and take off the panels, it makes it very tight to try to attach the filter to the main part of the intake (there is no room to actually tighten the metal clamps. Thanks for the help.
it's a tight squeeze, but you have to go through the bottom and keep working at it to get the metal ring clamp on. I'm only 170lbs so I was able to actually squeeze my whole arm from under the car, without using a jack. It make take you a while to get the filter on. I tried for about 15 minutes the first time I tried to get it on. Then I took a break for a little while and ended up getting it on there the first try after my break. Good luck! Don't give up!
Another way is to jack it up and remove the tire. Remove the front inner fender, and the space where the filter goes is so accessible you won't believe it. It makes it much easier than going through the bottom. Especially when it comes time to tighten the clamp.
I found that drinking more beer, swearing and throwing tools at the damn cat that walks on my car helped my installation go better.
Actually, it just takes patience and try putting a little oil on the filter where it attaches to the plastic intake. It will slide on easier.
Thanks for the help. I kind of figured i was going to have to go from the bottom. I must say, this site is excellent. Everyone has helpful hints and responds very quickly. Thanks again for the help.
Chad
Chad
tdigger9899
Sep 7, 2015 10:56 AM
