Just hit 83K on my car...what sensors plugs wigits and dodads need replacing?
I am in the prossess of having little things go bad on my Z..its got 80K plus on it....
I need a complete list of everything that need replacing on the LT1..sensors and the likes..last time they were changed was like 27K..but the car is starting to run rough.. |
If your not throwing codes, then the sensors are OK... Just replace all fluids and check plugs and wires... Also throw in a can of Seafoam..it will clean out the system....
93Z Will |
If it ain't broke... don't fix it
Well anything dealing with the ignition will start to peeter out. i.e. (opti, coil, plugs, wires, O2 sensors) All of which i did myself ,and if i can do it, anybody can.
But like they said, if its not broken or throwing a code, then dont fix it. Chris |
