just had my car scaned, code 42'- and 36?
I just had my car sacned, it has 2 codes
42-->Ignition Control (IC) circuit (shorted or grounded circuit)
36-->Distributor ignition system (faulty high resolution pulse or extra low resolution pulse detected
are those codes fron the opti?
Re: just had my car scaned, code 42'- and 36?
ummm..My guess would be a bad ground, try new plugs and wires..If that doesnt help you might need a opti. How old is all of that stuff? Is it hard to start? does it cut off or surge?
Matt
Matt
[QUOTE=luis nunez]36-->Distributor ignition system (faulty high resolution pulse or extra low resolution pulse detected
QUOTE]
Doesn't look good. About the only things that will get the car to throw this code is the opti or the wiring from the opti to the computer. Although the presence of that code does not neccessarily mean your opti is dead, and vice versa. Good luck.
QUOTE]
I wouldnt worry about them too much. Just clear the codes and see if they return. If the car is running fine then they are probably just a fluke. I get random codes every once in a while and the only reason I know is b/c I have a scanmaster in my car otherwise Id be like 90% of the ppl on this board who think b/c theres no SES there are no codes stored in the PCM.
Matt
Matt
yes the car is hard to start sometimes, the plugs and wires are like 2 weeks old
so this maybe isn't the opti?
check the condition of the opti connector. clean it if needed and clear the codes. I would bet that you have lost your high res signal. This is why you have extended cranking time and will probably notice poor fuel econ and lack of performance
days before it startet to act, my mpg was poor hum.. shoebox.. the opti conector is the one that is over the opti?
just came back fomr the shop.. the only code that has was the 36 and the guys told me that he revs the car to 3k and the computer isn't getting signal from the crank sensor
Dec 1, 2014 08:08 AM
Jul 4, 2005 05:00 PM
