Just got my car, problem?
hi, im new to the forum(6months), just got my car from a dealership 2 days ago... its a 1996 camaro z28 m6.. everything is stock w/ the exception of a skip shift deactivator to my knowledge... it seems like everytime i get in my car i smell gas.. today i got out of work, went to a parking lot, did one little 360 and i smelled it again, it also happened when i drove from the dealership to my house (100 miles)... it doesnt look like theres a leak, can someone just help me out?... if you cant tell, im new to this, thank you in advance
Re: Just got my car, problem?
Did you drive it a little earlier before you got off work ? If so, you're cat's may be gutted or gone.
When mine started smelling like gas, I checked the fuel rail, seemed to be leaking onto the intake. Notice any spuddering in low RPM, or hard starting? |
my shift is from 3-11:30pm, i just moved my car at around 7:00pm about 200yards... so i doubt it has a gutted cat, it doesnt sound like it has a gutted cat either, i guess i will check the fuel rail.. and this is my second day driving stick, but i think i may have had some spuddering at low rpms, i didnt htink twice about it, but no hard starts occured, it fires every time. thank you and hopefully that is the problem.
Could also be the EVAP system. This system vents the gas vapors from the gas tank into the intake manifold. There are many components to the system, including a charcoal canister that is housed next to the driver-side back speaker, where the rear passengers sit. Take a look at these links:
http://shbox.com/1/1996_evap.jpg http://shbox.com/1/evap_sol.jpg |
http://shbox.com/1/1996_evap.jpg http://shbox.com/1/evap_sol.jpg Vinny |
I was smelling gas for a while to, it turned out to be a cracked header.
thanks for the replies... tonite no gas smell, and after i smelled it yesterday i check the gas cap to see if the dealership locked it in place b/c they filled up the tank, i made sure it locked... hopefully i dont smell it again, but if i do i will check the fuel rail nd the evap system... thanks again, and if anyone has any other ideas please share...
