jb weld oil pickup?
jb weld oil pickup?
so i tapped in my oil pickup tube and it was nice and tight...so after letting it sit for a day i came outside to find the pickup on the floor...im thinking about smearing some jb weld on the part of the pickup that slides into the pump and letting it sit for a day or 2....anyone ever done this? think it will work?
Jegs has a clamp for holding on the oil pump pickup- you will spend just as much in shipping to get it.
I welded mine on and put the clamp on after putting lock-tite on all the bolts..oil is kinda important to your motor- don't take ANY chances
Hell no on the JB Weld. I would not even run an aluminum pickup. What is the benefit of aluminum? Get a steel one and weld that thing on solid. My pickup fell off recently and it was a miracle I did not lose my motor.
I had a issue like that with getting mine in, I had to put the pickup in the freezer and warm up the pump. I don't know if yours was not seated in all the way like mine was, give it a try if your not sure you had it seated in all the way.
well i didn't buy an aluminum pick up for performance...its the only one that summit had in stock when i ordered my oil pump.. im pretty sure its aluminum since it looks like it...how can i be sure?
I don't know why a new pickup would just fall out by itself after install. Usually they are so tight, they are extremely hard to get in. Something doesn't sound quite right.
lol i found out its not aluminum it just looks like it
squarehead
Nov 21, 2014 08:02 PM
