J/w whats the most extreme engine mods you can do?
I was wondering bolt ons aside, and f/i aside, what is the most extreme things you can do with a 350 lt1? For example, what setup would yield the most hp with at least some stock parts.
Guest
Posts: n/a
Re: J/w whats the most extreme engine mods you can do?
With stock parts you are going to be somewhat limited. You could build a pretty stout 355 using the stock block, crank and rods (might want to upgrade on the rods though!). Buy a good set of forged pistons to use and have the stock heads max ported with larger valves. Then use a solid roller camshaft and valvetrain to match and add a good shot of juice and you will make some good HP.
take off down the track and at the 1/8 mile spray a 500 shot and coast. and call it a day. till you build your new motor. (note: spray till it blows up)
Bret
This question is sort of like asking "How much money can you fit into a 1 gallong jug?" Well - that depends what denominations of bills you use. Speaking of bills - how far you take that Lt-1 depends how much money you have. When you say "use some stock parts" what are we limited to - the stock oil pump and pan? Stock camshaft and heads (unported heads?). The question is really broad.
jb4xx
Feb 2, 2015 10:00 PM
johnsocal
Jun 22, 2002 12:18 PM
