intermittant engine codes
so recently i get a SES light come on frequently, but doesn't stay on for more than 15-20 seconds... sometimes right when i start up, sometimes when i'm driving around corners... seems to do okay on straight a-ways which leads me to believe something is lose or grounding out...
16 Lo - Res Failiure 48 Mass Air flow system failure 43 ESC Failure 34 Map sensor low 51 PROM/FLASH error... dont know what all those codes have in common, but seems like an electrical issue or PCM issue to me. |
Re: intermittant engine codes
Sounds like loose connection could be it.
| All times are GMT -5. The time now is 07:23 AM. |
