Intake gasket
Old Jun 17, 2006 | 09:51 AM
bcanz's Avatar
Intake gasket
I believe I have my oil leak pinpointed to the intake gasket. I am going to try to repair this myself. I have never done this before. What tools will I need before I start? Is this a difficult job for someone who has never done this before?? Thanks.
Old Jun 17, 2006 | 10:21 AM
RobbyRob's Avatar
Re: Intake gasket
Very easy to do. Just make sure your very clean. Blow the intake off before you start.Take a picture of the intake. It helps to remember where the hoses and wires go. Also masking tape to number connections. Take a peice of cardboard cut holes to hold intake bolts in order. All of this will help keep everything together. If you need more help. Send me a p/m. Also you can check out Shoebox's site. Good luck
Old Jun 17, 2006 | 10:24 AM
Loadre's Avatar
Re: Intake gasket
First off what are the symptoms of the oil leak?
Old Jun 17, 2006 | 10:28 AM
bcanz's Avatar
Re: Intake gasket
The rear portion of the intake is covered in gunky oil. Its either that or the main seal. I get a few drops everytime I park it.
Old Jun 17, 2006 | 11:01 AM
Bersaglieri's Avatar
Re: Intake gasket
Probably the infamous rear intake oil leak due to GM's lack of correct sealant application.
Here's a link to Brents site for a walk thru : http://www.bfranker.badz28.com/fbody/intakefix.htm
-Dustin-
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
dfarr67
Apr 10, 2015 07:44 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
