Installing a used cam
Just wondering what everyone thinks about putting a cam in with 111k miles. Also, I see used cams for sale, is it unwise to install one? I see where some people install the cam, and the motor loses oil pressure shortly after and cooks the rod bearings. Is this from not replacing the cam bearings at the same time? Can the cam bearings be replaced without pulling the motor? Right now I get 50psi WOT and 25psi at idle on 10w-40 Yamalube.
Thanks,
James
Thanks,
James
to replace the cam the front of the motor is comming off, water pump, opti, all assories, timming chain cover and timming chain. The intake manifold and everything that goes with it, valve covers, push rods,spider, lifters,oil pump drive. O while I'm in here I probly should change this or that, O sh** this or that broke. A lot of work for a used cam.
I have done many many cam swaps over a 25 year time frame and have never had any problems. I have only done 2 LT1 cam swaps with no problems.
Just take your time. A valve spring change would be a good choice even if your going to install a stock cam as the valve springs get week over a long period of time and are not to bad to install. Curt
I do not mean to step on anyones toes. this is just: imo
i bought a used custom ground cam and my car has 137k miles. I replaced all the other valvetrain parts, the lifters, pushrods, roller rockers, timing chain, springs, and the necessary accessories with the springs. I didn't replace the cam bearings or anything like that, but so far I haven't had any problems, my tranny broke twice and the motor is still haulin ***.
I also had to replace my optispark but that was cuz a dumb *** friend of mine spilled coolant on it, but that was one of those "O sh*t, this broke" items haha
Thanks guys. Is it necessary to replace the lifters when putting in a cam? Definatly holding off until this car isn't a daily driver anymore. Hell, I may buy an extra motor to hop up and swap engines... I hate working under the hood of these cars, there is no room.
when you remove your current cam, take a look at your front cam bearing and whatever other ones you can see. if they appear to have a good bit of wear, i would probably replace them..but since you have pretty good oil psi theyre probably ok...depending on what cam you plan on going with with will decide if you need new lifters and springs..what lift will this cam be and whats the rpm range?
Looking into the cc306, 1.6 NSA rr, chome-moly pushrods (what length??), LE1 head w/ stainless valves and beehive springs. I just saw a user post almost the exact setup I want for my car, but I had already spent all my cash ordering an S60.
I do question the split, intake and exhaust, grind of the cc306 and how much it kills the dynamic compression.
Maybe this is a discussion for another topic......
Curt
