installing a procharger system
I just ordered a "1993-'97 Camaro/Firebird Stage II Intercooled with P-1SC - 8lbs of boost with 2 core intercooler" system from ati procharger for my 1993 Camaro z28 my questions are as follows;
1)What size fuel injectors do you recommend for this application???
[i know the 93 lt1 has smaller injectors then the 94-87 models]
2)What other upgrades will I need to do on my fuel system for the best possible results from this supercharger???
[Such as a larger fuel pump, fuel rail, or other related items...]
Thank for your time,
theendofsound@comcast.net
Re: installing a procharger system
Ditch any type of FMU the system might come with. Go 38lb injectors or higher. NGK tr6 plugs gapped at .35 a must. Upgrade from stock fuel pump to my personal opinion racetronix pump kit 255lph high output.
GET IT TUNED!!!!! most important advice.
Adam
Adam
