Installing headers?? Long Tubes
Old Feb 15, 2005 | 09:04 PM
nonamez28's Avatar
ok well before i buy headers, i want to know the difficulty of intalling these..
can you do it yourself?
a day project?
pretty easy, just takes a while?
also with long tubes do they hook up to the stock exhaust piping? or do you have to have that moddified?
let me know the detals fellas
thankyou in advance
Old Feb 15, 2005 | 09:10 PM
FryedClutch's Avatar
Re: Installing headers?? Long Tubes
well i can do it myself a friend or pair of friends helped but yeah
its a day project (or night if you start a 8 pm like i did) for a newb its about 12 hours worth of work
and for LT's you need an off road y pipe for it to meet up with the stock exhaust but even then you need to do some mods to the stock exhaust (mainly just cotting about a foot of the I pipe
Old Feb 15, 2005 | 09:18 PM
nonamez28's Avatar
ok? so basically you need a welder to do this project?
and what type of y pipe?
Old Feb 15, 2005 | 09:20 PM
baron4406's Avatar
They say the hardest part is getting all your old stuff off, I kinda belive that since when I went to Hooker LT's to RK Sports (emissions) it was ALOT easier than the original swap from manifolds to LT's. You honestly wanna know the hardest part?? That friggin, godawaful DIPSTICK. I actually have a permently disfigured fingernail from the RK swap. Getting that dipstick back in almost drove me insane (well more insane)
My final impressions were while it is a pretty tough job, its nowhere near as hard as most people make it out to be. Just take your time and think things through.
Old Feb 15, 2005 | 09:24 PM
noo ya dont need a welder it might be a nice finishing touch but not neccesary
iv got pacessetar Long tubes and the pacesettar y pipe
the y pipe is slip fit so it just slips on to the collecters of the headers and then you use exhaust clamps to clamp it down
Old Feb 15, 2005 | 09:25 PM
nonamez28's Avatar
i am used to honda motor swaps so i got the turning bolts part......
question.. if you have to put the y pipe on from your LT's do they have to be welded? and can you drive a LT1 jsut open header? to go get it weled?
Old Feb 15, 2005 | 09:28 PM
nonamez28's Avatar
how much did that set up cost you? and do you make good numbers? some guy was telling me that pacesetters sucked today...... i really didnt know
Old Feb 15, 2005 | 09:29 PM
check your other thread for welding comments but
i actually recomend you drive your car at least once with open headers cause it just sounds so good
and the pacesetter coated lt's and y cost me about 500 bucks
and they actually are really nice pieces
i dont have any numbers yet but i can tell you that the night i got the install finished up i took her for a test drive and on 235 street tires in about 40 degree weather i shifted into second and blew up my rear end
so im assuming that there was a significant power increase lol
Old Feb 15, 2005 | 09:52 PM
nonamez28's Avatar
that doesnt sound good blowing up the rear end bud
Old Feb 15, 2005 | 10:18 PM
yeah it sucked then but the 4.11 gears and new posi which i needed made up for the loss
Old Feb 15, 2005 | 10:20 PM
nonamez28's Avatar
give me info on where i can get the same setup as you
Old Feb 15, 2005 | 10:38 PM
'94 Bad A Z28's Avatar
It can be done a few short hours with you and another person.
Old Feb 16, 2005 | 12:44 AM
Crazy95Z's Avatar
Looking back on my header install, make sure you have a nice jack and are willing to use it on your oil pan to get the Pacesetters in there.. I was kind of leary about it at first but as was well after it was done. You will thank yourself after you drive it and every other time you go to change plugs.. Trust me.
transam_388
Mar 15, 2015 11:53 AM
Cam's maro
Jan 30, 2015 09:21 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
