installing a double roller timing chain....
Old Jun 18, 2003 | 02:48 PM
yorkie's Avatar
seems like the clearance is very little there, do you grind the aluminum cover where the chain is, seems like it will be very close and the chain will be the part sticking out the most???
The crank sprocket seems ok.
Old Jun 18, 2003 | 03:10 PM
atljar's Avatar
Yes you will need tio grind on the timing cover a little. i sprayed my chain with white litheum grease, then tightened down the cover. Unbolted cover, and sprinkled blue carpenters chalk all over it. It sticks really well to where ever any grease from the chain rubbed off. I had to repeat this about 3x to get it just right.
Old Jun 18, 2003 | 03:46 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
you can use that blue grease too-thats what i did to check clearance with valve covers on rockers-
i wouldn't drown it in there though
personally i'd grind the cover, then put a tiney bit of indicator (whatever you use) on the cover and then spin the assembly
Old Jun 18, 2003 | 04:50 PM
yorkie's Avatar
no dykem or grease needed, it was hitting bad,
down to just touching now, I will go more because the chain floats fore and aft.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
97 RedSS
Jun 10, 2003 07:58 PM
