CamaroZ28.Com Message Board
-   -   Which injectors to use? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/injectors-use-367004/)
Gripenfelter May 13, 2005 02:52 PM
What would be the next step up from 30# SVO injectors?
I couldn't find 36# SVOs. Apparently they stopped making them.
Looking for something that doesn't ruin my idle and will be easy to tune. I use PCMforLess.
fireman May 13, 2005 03:42 PM
Re: Which injectors to use?
I just bought some 42lb SVOs.
Gripenfelter May 13, 2005 03:48 PM
How is your idle?
fireman May 13, 2005 06:34 PM
I'll let you know when I get 'em on.
jay_lt4 May 13, 2005 06:51 PM
42# delphi here, working perfect, good idle, easy to tune
JustNO May 13, 2005 08:03 PM
there are 37lb racetronix.. I use them and its perfect.. You should go with them.. 30 is too small.. 42 will be big.. 37 is the size that should go.. (according to the injector formula)
Racetronix May 14, 2005 03:33 AM
Buy an injector to meet your long term requirements.
