injector wiring ?
Old Dec 24, 2003 | 02:06 PM
polcat1p's Avatar
injector wiring ?
I'm converting my 93 lt1 into a 94. I got a 94 harness, and need to know if it makes a diff. what wire goes to what injector.
Merry christmas
Chad
Old Dec 24, 2003 | 05:50 PM
HBHRacing's Avatar
I do not know of a difference. they should be the same. the pink wire is the fused hot feed and the grenn wire is the PCM ground pulse....
Old Dec 24, 2003 | 06:06 PM
slopokrodrigez's Avatar
There is a huge difference. The 93 is batch fired and the 94 is sequential. There are inumeral changes that go with it. 94s have a MAF that 93s don't and obviously programming differences. In the 93's the wiring between banks for the injectors doesn't matter, in the 94 and up each injector must be wired correctly. This is not something the average person can accomplish.
Old Dec 24, 2003 | 06:12 PM
HBHRacing's Avatar
I really hope a 93 comes into the shop one day. I need to spend some time poking around one. I have yet to work on a speed density Fbody.
Old Dec 24, 2003 | 09:39 PM
SWINGRRR's Avatar
You should have put this on www.speeddensity.org I would have seen it alot earlier. I can send you the diagrams from the 93 and a 95, the same as a 94. Dont be a stranger now!
Old Dec 24, 2003 | 11:17 PM
polcat1p's Avatar
I know there is alot involved into the swap. I already have the 94 (comp., harness, mass air, heated o2s, ect) I was just wondering if there was someway to find out which injector wire goes with which injector. When i took off my 93 harness i labled everything. Not so lucky with the new 94 haarness though.
Chad
Old Dec 24, 2003 | 11:22 PM
ibanez6rg's Avatar
I just learned this, but there is big white numbers on each harness that tells with injector it goes to.
Old Dec 24, 2003 | 11:52 PM
So true .
Old Dec 25, 2003 | 12:49 AM
polcat1p's Avatar
THANK YOU..
So # 8 on the harness would go to #8 cylinder, or injector or does it matter.
Thanks again guys i was really sweating this.
Chad
Old Dec 25, 2003 | 08:43 AM
ibanez6rg's Avatar
Originally posted by polcat1p
THANK YOU..
Chad
Yulp. 1-1, 2-2, 3-3, 4-4, 5-5, 6-6, 7-7, 8-8...
Alex Barnes
Jan 24, 2015 10:21 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
