im having probs with plug # two! help
Use a piece of hose slipped over the porcelain to give you some added reach. Make sure you get it threaded in by hand, because you don't want to gimp the threads. (been there, done that on #2
Originally posted by 97WS6SCharged
Did you try the "hose" trick?
Too slow on that one.
I like the post of some guy that said he found a new plug access tool that works great...his 13 year old daughter.
I always used that trick on my 77 Z28. It worked well enough, but I never could get the angle right for the TA.
My S10 was the easiest thing in the world to change plugs on, with the exception of my sister's honda car. There were no fender wells so I could reach in, remove the plug wire, and swap the plugs on the ones I couldn't reach from the top.
BTW, when I had my accessories out a few weeks ago (everything but the AC compressor), I still couldn't do anything with that particular plug from the bottom of the car.
Let's see, 13 years, 9 months, and however long it takes me to knock up the girl friend till I get my new spark plug tool. Then i have to hope it's a girl.
you can't even get the plug started? if you can't get it started i dunno what to tell you.
but i developed a trick of tightening the plugs once you get them started. this will only work if it's the kinda socket like i have (MAC tools), or maybe some others do, if it has the little hole that goes all the way through for the little ball on the drive of the ratchet.
put a regular 5/8 inch, 1/2 inch drive socket on there. not a deep well. you need to put it on there with that little hole facing up. it should go all the way on there, the porcelin part of the plug will go through with the 1/2 inch drive. then take a punch, and stick it in that little hole and turn it, it'll only turn 1/4 turn at a time or maybe only 1/8 turn at a time. it takes forever but it's the only way i could get #2 tight.
i did all that with everything on(alternator, AIR, etc) ......last night as a matter of fact. on plug #2, so i know it works. atleast for me.
edit: i have headers....so that makes a difference.
Yeah, you could use a name brand tool, or...
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
It's just like the one I made, and less frustrating. Yep, I bought one when I lost the one I made.
hee hee...cool, i might get one of them....do you have one, does it work?
im still having problems and i just dont have the right size of hands in 6 5'' so my hands are huge and with my left hand i try to guide the hose but i just cant!!!
i need help!
the air on the manifolds are on the way is there anything i could do to take them of or is it a pain?
how can i do it from the bottom?
im so frustrated cuz i just finished the opti instal and this damm plugs is delaying me!!!!!!!!1
should i just call a mecanic for him to do it???
i need help!
