Ignition switch wiring
Old Nov 6, 2013 | 08:29 PM
99RAMAIR's Avatar
Going through the wiring on a 94 Z28 and am wanting to see if a wire is right.
It is a pink wire going to the ignition switch. There is a resistor installed on it.
Was it this way from the factory or did a previous owner install it? If so what would be the purpose? If I'm reading right on the schematics; it is going to the injectors from the switch.
There is also a resistor installed in the Vats wiring, so someone probably added the above in the pink wire, but I don't know why.
Thanks.
Old Nov 6, 2013 | 10:05 PM
Re: Ignition switch wiring
There would not be any wire going to the injectors from the switch nor a resistor on there. Maybe it was part of a remote start that was on it before?
Old Nov 7, 2013 | 07:54 PM
99RAMAIR's Avatar
My apologies. Mis-traced it last night. The pink wire with resistor is going to the long connector right below the ignition switch.
Old Nov 7, 2013 | 09:10 PM
Again, it is something added on and not from the factory.
Old Nov 7, 2013 | 09:39 PM
99RAMAIR's Avatar
Below is two photos of the connector and the last is the wire with heat shrink. The resistor is under the heat shrink. (the lowest wiring hanging; hard to tell with the lighting)
Old Nov 7, 2013 | 09:41 PM
99RAMAIR's Avatar
Thanks for the replies on all my posts. I search through your site almost daily.
Heathen1
Jan 2, 2016 04:27 PM
robcarnut
Mar 20, 2015 03:40 PM
lbrowne
Nov 13, 2011 04:25 PM
Jul 4, 2005 05:00 PM
