Idle Vid - LE 2.2 cam + LT's - cats through 3.5" mufflex and spintec muffler
Had to start the car today it hasnt been ran in over a month (rear end detonated, saving up for 12 bolt) Decided to break the new digital camera out and make an idle video. Just thought i would share.
http://videos.streetfire.net/video/e...2101088725.htm Steve |
A lot of echo. Bet it sounds better in person.
Sounds mean. Now get the rearend fixed and see what she can do at the track.:D
What's she idle at?
From the pcm if you can read it. |
Sounds really good
Idle is set at 1100 i believe. Its been so long since we tuned it i dont exactly remember. Im pretty sure 1100 though.
Steve |
Sounds healthy! :thumb:
sounds good,.
if going by the factory tach, it might be 200 RPM lower than that. I know my tach shows 1100 RPM but scan master and Tuner CATS shows 900 RPM. |
Same here Lloyd, my tach reads 1100 but on the Datamaster it says 895 RPM. I cant see the vid cuz its blocked here at work, but I bet it sounds real nice. Im running the same cam, but I need to get the heads :( .
Yeah, it sounds very similar to mine.
