Idle stumble
Idle stumble
Tried searching...saw a lot of low rpm miss stuff, but that isn't me. Yet, anyways. Engine stumbles at idle in drive when hot...doesn't do it cold. It is somewhat better in neutral and Park. It also trembles in drive and reverse slowly moving forward or backwards. There is no difference that I can tell at highway speeds or accelerating, not since the problem initially occured anyway.
Thanks in advance everyone.
Vacuum leaks are a major cause of surge and rough idle. Best thing to do is search for a vacuum leak. They are very hard to find, but you notice huge differences in performance once the are found. Another good idea is to thoroughly clean the TB. Deep Creep from Seafoam is a great solvent and its sensor safe. Clean your Idle Air control Valve located under the TB.
Now your situation could actually be mechanical related such as EGR valve or Oxygen Sensors. But its best to start small and clean what you can first. Good Luck
Re: OK
Originally posted by shadydavy 95 TA
...I will make sure the MAF, TB, and IAC are clean when I get the chance then. I did get a little happy with the K&N oil last time I cleaned my CAI.
We'll see if it helps...
tommalcolm
Sep 11, 2015 03:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
