idle relearning
I think my car has become acustomed to idling happily with the heat on floor at fan speed 3. How to i get it the pcm to forget that and idle the same way with the fan off.
thanks for the help |
There should be no change in idle from what you describe. Only if the a/c compressor was engaged should the idle be much affected.
If you want to try to reset the IAC, do this: -Depress accelerator slightly -Start engine, then release accelerator pedal, run engine for 5 seconds -Turn ignition "OFF" for ten seconds -Restart engine and check for proper idle operation |
Thanks for the help.
| All times are GMT -5. The time now is 08:19 AM. |
