Idle is 1500-1800 rpms after driving ... is this the TPS ...
Old Jul 16, 2009 | 12:40 PM
TDog's Avatar
Hi Guys ...
While fixing what turned out to be some ignition problems, I decided to pull the throttle body and do some cleaning ... I was very careful to not damage the IAC and TPS sensors ...
But ... I must have ... whenever I drive the car around and then come to a stop, the idle stays at 1500-1800 rpms until I apply a little tap to the accelerator and then then idle drops back down to where it should be ...
I originally figured that I damaged the IAC, so I purchased a new one and I still have the same issue ... the cable linkage is not binding and no other noticeable issues ... so I'm assuming the TPS got damaged somehow ...
Would you all concur ???
Old Jul 16, 2009 | 01:49 PM
Joe B's Avatar
Originally Posted by TDog
Hi Guys ...
If you've Installed & RE-set your new IAC properly.....Example: Measured to make certain that it's "Pintle to mounting surface" is no more than 28mm (if it's greater, press it in gentely with your finger)......RE-set method as follows: Depress gas pedal slightly.....start the engine, and release gas pedal.....run engine for 5 seconds.......Turn ignition "OFF" for ten seconds.....RE-start engine and check for proper idle.......If having same issues.... Getting a scanner reading on the mentioned sensors would be my next step.....If you don't have a scanner handy....Atleast put a voltmeter on your TPS to see what it's doing......Correct parameters you'll be looking for are in link here http://www.golenengineservice.com/html/tps.html ..............Joe
Old Jul 16, 2009 | 02:00 PM
TDog's Avatar
I performed that process when I installed the new IAC ... I don't have any issue with idle at initial start up and didn't prior to installing the new IAC ... I only have issues after the car has been drive some and the RPMs see around 2500 or higher ... Then whenever, I come to a stop the idle sticks at around 1500 or slightly higher until I tap the accelerator and then it drops back down where it should be ...
Old Jul 16, 2009 | 02:09 PM
Joe B's Avatar
I performed that process when I installed the new IAC............That's good, I just figured I'd put it in case you didn't.........Then like mentioned....I would scan it (IE: operational data) so you can see exactly whats happening when the issue occurs
grgguy
17
Feb 23, 2015 07:57 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
Aneurysm
Jul 22, 2002 08:42 PM
Redbird
Jul 20, 2002 06:08 AM
