CamaroZ28.Com Message Board
-   -   Identify these pieces? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/identify-these-pieces-421626/)
Jeff95TA Jan 10, 2006 11:11 AM
These threads are always amusing (if it's not your car!)
Tearing the engine down and found these in the oil pan. Having trouble identifying what they are. Haven't gotten the rods out yet to investigate further.
http://home.comcast.net/~saccani/DSC02081.JPG
96flame Jan 10, 2006 11:55 AM
Re: Identify these pieces?
can't tell but it looks expensive
Jeff95TA Jan 10, 2006 02:29 PM
Good answer.
It's pretty thin metal. It's not what I thought a bearing would look like, but I can't think what else it would be. Major destruction like this is new to me.
multicar Jan 10, 2006 04:58 PM
Windage tray, roller lifter spyder(guide), oil pump pickup......?
Doug
93black-ta Jan 10, 2006 05:08 PM
i agree, it looks to be a windage tray or spyder. im curious to know what they are also. i cant think of how a spyder could get chewed up like that.
RICEFEDZ28 Jan 10, 2006 05:14 PM
yep i'd say windage tray.
crAzy95z28 Jan 10, 2006 05:14 PM
looks like a piston ring >?
93black-ta Jan 10, 2006 05:34 PM
if he's got the pan off he'd know if it was the windage tray though.:confused:
Jeff95TA Jan 10, 2006 08:33 PM
Whatever it is, there's a shredded piece of it stuck between the number 3 rod & the crank:
http://home.comcast.net/~saccani/DSC02101.JPG
And is this what the windage tray looks like. Is it just a single piece of formed metal? No bottom piece to it or anything?
http://home.comcast.net/~saccani/DSC02102.JPG
93black-ta Jan 10, 2006 10:38 PM
the windage tray is fine. im at a loss, those peices dont really look like bearings but anything is possibe. keep us informed
oneslowz28 Jan 10, 2006 10:50 PM
there peices from the rod and main berrings im almost 100% positive
LT1 POWR Jan 10, 2006 10:51 PM
About how big are the pieces in the first pic. I cant really get a good perspective. Maybe you could put a ruler next to them or something.
oneslowz28 Jan 10, 2006 10:52 PM
yep from looking at that pic your rods and your crank are shot. plan on replacing the crank becuse if a motor chews up the berings liuke that the crank will be to far out of spec to be fixable
HardcoreRM125 Jan 10, 2006 11:40 PM
I really dont think that could be a bearing. If it was a bearing, that motor would absolutlely have thrown a rod, or something horrific. I think it may be a Lifter Spyder.
The piece on the far right of the first pic, does look like a piston ring, but I think that may actually be a piece from the lifter as well that got bent to a suprisingly circular shape.
Did you notice the little pieces stuck on the screen of the oil pic up? When you rebuild that motor, dont let anything go unchecked. You definatly need to flush the oil passages all out before reassembly. Although any reputable shop will clean the parts after they repair/rebuild for you.
MaxLean Jan 11, 2006 02:50 AM
Definitely a bearing. Must have been making quite a racket.:eek:
