ICM and Coil gettin hot as........
and yes ive already done the cool mod years ago. any ideas? Im trying to troubleshoot the car randomly dying, so i figure the ICM is toast but Id hate to replace it just to have another one cook.
I feel like the ICM spacer mod doesn't do much, you're spacing it with metal washers, heat will still transfer there. Try washers wrapped in heat tape, I plan on doing something like that unless it is supposed to be grounded to the head or something? I could be wrong though and what am suggesting may not be any better.
Some people have posted that spacing the ICM away from the head solved their hot engine spark issues. So, it does work to some extent. Then again, lots of people have it in the stock location with no problems.
Im just assuming it is cooking because it has alwasy gotten warm while running.
I installed a new coil about 4 days ago from orielly auto parts, and that is when this started. Now when the engine reaches operating temp the coil and icm are hot enough to burn your fingers.
weigh2fast4u
Jun 28, 2015 08:28 PM
