CamaroZ28.Com Message Board
-   -   A.I.R valve question (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/i-r-valve-question-465084/)
976speed Aug 6, 2006 03:53 PM
I have jet hot long tubes on my car and i had my pcm tuned to delete all emissions codes, i ended up losing my air valve and tubes to hook it up on the passengers side header, can i just take the other one off and cap them or will that mess anything up???
deputydough Aug 6, 2006 05:43 PM
Re: A.I.R valve question
not sure about the 97. my 95 doesn't have any of it. runs fine without it. obd2 may not be as forgiving.
jonota Aug 6, 2006 05:46 PM
If the PCM has been tuned to delete it, you should be able to remove the entire system and have no problems.
Jonota
