I need suspension help
Old Dec 8, 2003 | 10:15 AM
john96ws6's Avatar
I am in the middle of gathering suspension parts for a winter project. I ordered a bunch of adjustable spohn stuff and I will be ordering HAL QA1 shocks, but I am not sure what springs to get. I have Hooker LTs so I am not sure the car can handle too much of a drop. I am not sure about Drag Launch springs because I don't see much track time (It's 2 hours away). How do Drag springs affect handling? I am looking for an all around fun car to drive. Is there a stiff lowering spring that doesn't lower the car too much?
Old Dec 8, 2003 | 01:07 PM
john96ws6's Avatar
No one has a suggestion?
Old Dec 8, 2003 | 01:45 PM
OldSStroker's Avatar
What are your specific goals? How low, how hard and why?
What other "stuff" are you using and why?
Old Dec 8, 2003 | 02:29 PM
bruecksteve's Avatar
You could use coil overs and adjust to the height you need.
Old Dec 8, 2003 | 02:47 PM
john96ws6's Avatar
I ordered a panhard bar, LCAs, front and rear sway bars. I also plan on ordering a Torque arm. I currently have Hooker LTs, 3200 vigilante, Subframe connectors, NX 100 shot, other little things. Future plans include Heads/cam. I want versatile car that can hold its own going straight and turning.
I don't know anything about coilovers. How do they work? Who makes them? How much do they cost?
Old Dec 8, 2003 | 02:56 PM
buelldevil's Avatar
Stock WS6 suspenion would fit the bill.
Old Dec 8, 2003 | 03:09 PM
RedPhenx's Avatar
if you're lowering it, i would lca relocation brackets also
Old Dec 8, 2003 | 04:03 PM
I agree.
Throwing parts at a suspension without a coordinated plan is probably a worse idea than randomly throwing parts at an engine to make it "better". There's a good chance you'll make it worse.
If you purchased other than black parts, the new stuff will at least look different. There are a bunch of people that like the bling-bling effect whether the parts work or not. No flame intended; that's not you, IMO.
Spending your suspension money on really good tires and maybe a set of Eibach or H&R springs (about 1-1/4 inch lowering), and maybe shocks would be my choice of where to modify. You'd improve the cornerning (tires mostly) and looks. If you drag, get a pair of 16 x 8 F-body wheels and put DRs on them for the strip. I doubt you'll need the LCAs or torque arm; a whole bunch of guys are running quick without them.
My highly opinionated $.02
Old Dec 8, 2003 | 04:17 PM
RedPhenx's Avatar
the lcas and stuff i was referring to keep correct supsension and driveshaft geometry, i would think lowering the car can adversely affect that.
Old Dec 8, 2003 | 04:32 PM
Heatmaker's Avatar
Advanced Member
The drag springs are stiffer and they make the ride feel firmer...but with the QA-1's I wouldn't worry about the Springs....the Hal springs are awsome. THier so adjustable you can take them from track to Cricle in a second. I used Drag springs in the front with the Circle track springs in the rear. Other than reducing brake dive a bit there's no noticable difference than when I had the Circle track springs up front. ALso don't worry about the ride height either if you ahve LT's you can set the QA-1's lower of higher how ever you want. THey allow you to go stock height or highr it's up to you and the spanner wrench.
Old Dec 8, 2003 | 04:48 PM
You don't need the LCA's even if lowered.
MY suggestion is to call Sam Strano at http://www.stranoparts.com and talk to him. He's the F-Body suspension expert. It will be the best call you've ever made for your car.
Old Dec 8, 2003 | 09:07 PM
john96ws6's Avatar
Thanks a lot guys I really appreciate the input.
Old Dec 10, 2003 | 01:00 PM
RedPhenx's Avatar
steve, you're right, I typed to fast and got myself confused.
I was thinking of something else
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
mrwz28
Jul 8, 2015 09:11 PM
