i need some help
Old Aug 1, 2003 | 08:13 PM
Bobbys_97_Z28's Avatar
i need some help
car when in park the rpm needle flickers a little bit...its supposed to be steady...you can just see it a little bit when you put it in gear...it goes away...car also had hesitation from stop to go...i already did air/fuel/pcv filter, new coil,cleaned iac, new plugs....need some more things to look at
Old Aug 1, 2003 | 09:45 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
*cough* opti *cough*
