i go from bad to worse lol
ok ..so i was reattaching the front "cover" of the water pump. ( thin piece of metal held there by 6 bolts, covers the fan) Anyway ...It was leaking from there before, so i tightened them too tight and i snapped a bolt of in the hole ...
lol ..what now?
lol ..what now?
Was there some reason you needed to take that cover off? There is usually no need to touch it. You are going to need to drill out the remaining bolt and extract it and you will probably have to remove the pump to have room to do it.
stars1010
Jul 15, 2002 03:51 AM
