How to remove the crank hub?
Old Feb 11, 2009 | 09:13 AM
cboggs5's Avatar
I have a 93 z28 and i'm replacing the crank seal. i'm having a hard time getting the harmonic balancer hub off. can anyone give me any tips?
Old Feb 11, 2009 | 09:19 AM
wile2k's Avatar
It has been a long time but I believe that you have to use a puller to get that off.
i.e.
http://store.summitracing.com/partde...5&autoview=sku
Something like that.
Old Feb 11, 2009 | 09:50 AM
cnorton's Avatar
Just be sure to remove the bolt that secures the hub to the crank as well as the washer that fits between the bolt and the hub. Failure to remove those items seems to be a serious stumbling block for a lot of people. I guarantee you that you will not be able to pull the hub off over the bolt and washer no matter how good your puller may be.
Old Feb 11, 2009 | 10:02 AM
smb72's Avatar
http://www.lt1engine.com/tech/remove...lt1-crank-hub/
Step by Step
Old Feb 19, 2009 | 02:55 PM
OBE1 95Z28's Avatar
You stated you're replacing the crank seal. The most common leak on the timing cover area is the water pump drive seal. Double check that it isn't your issue.
Old Feb 19, 2009 | 03:20 PM
user 647483's Avatar
This is how I do it ... works great. Even easier with an air-ratcher.
http://www.youtube.com/watch?v=qkh1BNM7e6Q
One tip; make sure to clean out the crank bolt hole before reinstalling.
Trace the threads with a tap if you have one.
You can borrow a removal/install kit from most auto parts store with a $30-80 deposit (100% refunded)
I've done it do many times, I just went ahead and bought the toolkit LOL
HectorM52
Jul 30, 2017 11:46 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
